Remove fairing and use plasti-dip.
Wheel tape. Brake reservoir sock. Brake/Clutch levers. Easy Ways to include yellow.
good point.im glad the whole bike isn't yellow it looks much better half and half. Like Tony said, tape off the areas you want to stay black and go nuts with plasti dip.
Do keep in mind plasti dip leaves you with a matte finish so if you want something glossy you should consider a plasti dip glossifier or even a straight wrap...
no you spray the plasti first, let it dry and then apply the gloss over top...How does the glossifyer work? Do you just mix it into the plasti dip? I think all yellow is a bit much. Some silver or black is a nice accent to the yellow. Mostly yellow --> sure. All yellow --> overkill.
yea exactly. The only thing though is i've head some people online complaining that the glossifier makes it look like a cheap paint job. You dont get that glossy depth like stock.makes sense, you basically treat it like clear coat. Seeing this video helps as you can really see the big difference that's made with the gloss spray.
one of the biggest plasti-dip "issues" ....SOLVED!
