1 - 11 of 11 Posts
ok,
Will 2015 Mufflers fit in 2013?
So anything I need to know before I put them? how about the Buttlerfly, is there any CPU issue or difficulty removing it?
Thanks...
oh if you ask is Because I can and I got them.
Reactions: novaks47
Discussion Starter #2
Found it!
remove muffler with both wires!
I like the stainless too. So just bolt on with wire change?
You will need the "servo buddy" or make one. If not, you'll have an error when you disconnect the stock exhaust valve.
I prefer the stainless look as well, but as far as the cans go, ignoring the finish, I like the older ones better. They look more modern to me. I really like the shape of the end-caps and outlet tips more than the newer ones. I'm not about to swap though, as I'm happy with the sound and sound level of the stockers, and I also don't want anymore black than what's already there, lol. Too much black on modern bikes!
Discussion Starter #11
They went in pretty good.
Removing the cables from the servo is all it takes, the servo stays there doing its thing, I think it thinks cables are still there LOL
The sound is deeper at idle, and that is it!!!!
1 - 11 of 11 Posts
