1 - 20 of 23 Posts
Was wandering if the 2014 air filter will fit the 2012, the filter part number is different but the filter gasket is the same part number
Discussion Starter #2
Reason, they say the 2014 filter flows alot better than the pre 2014 they are made different, and im not a fan of k&n filters
I called kawasaki parts department and they said the 2012 and 2014 had the same part number on there microfiche, i guess they are doing a little false advertisment on the 2014 ninja lol
From what ive read one filter is woven and the other is not, thats suppose to be the difference in air flow, i would definately take the one with more air flow since its oem and not having to oil it.
Noted and will do the air breather mod, im going to do the ivans flash this winter and finish up my mods, thats basically all i like, the headers im still up in the air about.
Discussion Starter #8
I think ill order that part 10065 also it looks totally different than the 2012
Discussion Starter #9
Parts ordered, wander if i will be allright with that new plate with holes and the new air filter since i dont have the flash yet.
It will be no problem. Just a better noise, is abotu it.
I was going to order the part, but a stepped bit and a drill did it in abotu 10 seconds.
Discussion Starter #11
Looks like the plate for the 2014 has holes all in it
Reactions: Mark59
I went to the local home depot and bought a small sack of 1/ 2inch holes.
Seriously, I did send one of our secretaries to the industrial supply house and ask that the 1/2 in holes be added to the order I called in.
So, I drilled mine to match, but as I was doing so, wondered why I left it in at all?
Yamaha claimed to enlarge the airbox of their mt 10 to boost low-mid. If thats true, might removing the plate do the same thing?
The 2014 bike has different length velocity stacks, too. Older was two short, two long. New bike is all four , medium.
Discussion Starter #14
Wander what it would do if you added those velocity stack
Discussion Starter #15
Discussion Starter #17
Good point rc when i do my flash this winter i think ill ask ivan what he thinks about the velocity stacks
Discussion Starter #18 (Edited)
The 2014 air filters are 10.00 bucks higher than the 2012 air filters,at babbitts parts hope i can keep the front wheel on the ground after i change it out lol
You must of put in the newer plate also, notice any differance, good picture explains it well
Difficult to say.
I did this with a new air filter (BMC) + Ivan's Airbox mod.
The intake noise is a lot nicer, but no idea how much is because of the resonator plate.
Discussion Starter #20 (Edited)
I got that plate full of holes comming also hopefully be here this week, babbitts dont put out much shipping info like most places i guess when it shows up you get it lol, i thought that plate with holes was the ivan air box mod, i guess this will be all i do untill i get my flash
1 - 20 of 23 Posts
