This stuff is amazing - Engine Restorer additive.
895 views 34 replies 6 participants last post by  rcannon409
#1 ·
I've used this on all my cars for 25 years, especially my high milage Hondas and Ford Escort. Proven to increase compression in older engines, by filling scratches in cylinder walls. So if you have an older motorcycle, can't hurt.
haha, accidently posted a picture of the reason California is going down the toilet. This website will not let me delete the photo.
#2 ·
Yeah, i dont know why editing is so restricted here.... cant even delete a post.
Its the same site owners as other pages i have been on, one i can, and the other i cant.
As far as the engine stuff, i wonder if it works with modern nikasil and other plate bores ?
Older stuff was just raw metal
#7 ·
In a decent, modern motor you would rebuild it if it ever needed the snake oil product you are talking about. Its performance would have fallen off so much that it wouldn't be useable.
Now that you brought it up, find one example where this product did what it was advertised as doing on a power sports grade motor and I'll read If about it. If you had done regular oil changes on the Honda car, it wouldn't have needed this in the first place.
Reactions: Energydrinkvape
#8 ·
From Chatgpt:
ChatGPT said:
Here’s what various users, reviewers, and mechanics have reported regarding engine restorer/compression restoration products and their effectiveness:
Real-World Test Results & Testimonials
  • Amazon Review – Skid Steer
    A user increased compression from 60 psi to 75 psi in one cylinder after only a few hours of use—an increase of 15 psi made them a believer.Amazon
  • Ametech Engine Restorer (UK) – Ford Vehicle
    After adding the product and driving thousands of miles, compression across cylinders measured at 115–125 psi—impressive recovery.American Technology
  • Ametech – Nissan & Other Vehicles
    Reports of smoother performance, reduced smoking, better fuel economy—with compression improvements experienced over weeks.American Technology
  • eBay Review – 22-Year-Old Engine
    Compression improved from 100 to 130 psi in about 10 minutes, engine ran quieter and more efficiently.eBay
  • BG EPR (Compression Engine Performance Restore)
    Manufacturer claims “outstanding test results,” with before-and-after compression tests showing improvements in individual cylinders and overall drivability.Amazon
    Customer feedback backs this up—for instance, one reviewer reported improved compression and dramatic oil consumption reduction on a high-mileage Kia Sorento.Amazon
Forums & Community Insights
  • BobIsTheOilGuy Forums
    Users report improvements:
    “Restore boosted the compression… we got about a 15# boost in compression and it evened out all 6 cyl so it runs a lot smoother.”Bob Is The Oil Guy
    Another said compression rose from around 131–145 psi to 194–206 psi on a shop engine.Bob Is The Oil Guy
  • Individual Case – Volvo
    A user recalled raising compression by ~20 psi in the worst cylinder and ~7–8 psi in another; noted better responsiveness and throttle control.Bob Is The Oil Guy
  • Reddit / r/cars
    Mixed perspectives:
    “The Engine Restore vehicle was the only one which raised compression and kept it there after the testing… the Engine Restore only raised it 3–5 psi … but the fact that IT WORKED was enough…”Reddit
    Some caution that it may harm modern VVT engines by clogging critical passages.Reddit
  • Reddit / r/prius
    A DIY endorsement:
    “Project Farm on YouTube tested Restore and it improved compression significantly on all four cylinders of his old tractor.”Reddit
    But others had check-engine light issues when used in modern VVT-equipped vehicles.Reddit
  • Skeptical Reddit Voices
    Some users dismissed it as “snake oil” and insisted that low compression requires mechanical repairs—not miracle additives.Reddit+1
Summary at a Glance
AspectObservations
Compression ImprovementUsers report increases ranging from ~3 psi to over 60 psi in extreme cases.
Engine Sound & PerformanceOften noted smoother idling, reduced rattles, better throttle response, and quieter running.
Fuel & Oil Usage BenefitsMultiple reports of reduced oil consumption and modest gains in fuel economy.
Duration of EffectSome say benefits lasted thousands of miles; others caution it may be temporary.
Risks or LimitationsPotential issues in modern VVT systems; some say it doesn't "fix" mechanical wear.
Mechanic & Community ViewsMixed—some hail it as a useful band‑aid, others warn it may be wasted money.
Takeaway
Yes, compression restoration products can deliver noticeable short‑term improvements, particularly in older, worn engines. Many users have seen measurable increases in compression and smoother performance. However:
  • These are not permanent fixes—an engine with worn rings, seals, or valves still requires mechanical repair eventually.
  • Modern engines with VVT systems might suffer adverse effects due to additive residue clogging oil passages.
  • Results vary—some users report robust improvements, others minimal or no change.
If you're seeking a temporary reprieve or want a diagnostic boost before a rebuild—and especially if your engine is dated or burned oil—running a compression restorer could be a worthwhile, low-cost experiment. Just be mindful:
  • Use it as instructed.
  • Run compression tests before and after.
  • Monitor performance and be cautious in engines with advanced variable timing.
#9 ·
The summary part sort of brings you back to the "is it really worth it"
But, it is up to the user, if it helps you, then go for it.
Fuel wise, a friend of mine used a Liqui Moly fuel system conditioner on his 4 cyl car, which he thought was running quite well after a suggestion from a spannerman, he was shocked to be honest.
It made a big chnage to the car. He and i both live up top of soome super steep roads, and he was able to hold 1 gear higher going up, and, he fuel economy improved by about 5 - 10 % depending on driving.
He monitored that, and felt it start to drifat back after about 9 months, but this time he used an injector cleaner and that brought it back again, he had used that one before with no results.
Screwed if i know what the L.M. stuff did, but he was happy
#10 ·
Part of the problem with the engine restore products is mentioned in the description. It's not permanent. Liquid doesn't turn into metal...well, except for 3d printing. If you have a scuffed up bore, or bad rings, that has to be repaired for any long term success.
Reactions: jjscsix
#14 ·
Imagine if someone really found a liquid that would fill wear marks in metal.
I don't think you could afford to sell it to consumers. Industrial customers would pay a lot more for the product. I believe you could charge 2000-3000 , per bottle, and still be sold out. Even if it only worked for two weeks, I can think of a few occasions where my boss would have yelled at me for not buying several cases of the magic product.
Reactions: jjscsix
#16 ·
Bob, you are the one who brought it up and told us how wonderful it was. That makes it your job to show some kind of proof. This isn't hard to do on products that have value.
#20 ·
I'll say that it doesn't work.
I've worked with companies who use fleet trucks and what they do is maintain their vehicles instead of neglecting them. A product, like this, isn't even mentioned in an emergency plan.
If you suggested it's use, you would be fired for incompetence as a fleet manager.
#21 ·
Kept two of my Honda Accords with over 200,000 miles running strong. Also keeps my 1998 Ford Escort running strong with 177,000 miles on it. But, its a free country, so don't use it if you don't want to. PS RC, please put some octane booster in your bike, and report back to us! lol
#23 · (Edited)
My 2011 Ford F350 service truck was sold with 305,000. The only service item it had was wear items. It was always overloaded by about 1000 lbs. This had the 6.2 gas engine
I did have the spark plugs changed at 225,000 just because the fleet manager was an idiot. He demanded the n"plugs and wires" be changed so I had rhe mechanic add in 125.00 for plug wires that didn't exist. He would have loved engine restore. Modern vehicles use stick coils. Plug wires disappeared years ago.
These were tools to do a job so maintenance was sketchy. The leasing company had a deal with jiffy lube and we changed the oil when we could.
Bob, I'm surprised that you didn't read/learn something about octane booster. It sounded like you might be interested enough to where you might take ten minutes to educate yourself, but I can see that I was wrong.
#24 ·
RC, why does Kawasaki recommend 91 octane fuel for our 11.8:1 compression ratio N1Ks?
#27 ·
From the AI Net:
The product "Engine Restorer" appears to be actively sold across various platforms, but specific sales figures aren't publicly disclosed. Here's what I found:
đź›’ Sales Activity & Availability
  • eBay Listings: Over 1,200 results for "Restore Engine Restorer" with multiple sellers offering different cylinder formulas (4, 6, and 8-cylinder) ranging from $3.25 to $26.95 depending on size and packaging.
  • Amazon Reviews: Products like the 8-Cylinder Formula Engine Restorer & Lubricant have received high ratings and positive feedback, suggesting strong consumer interest.
  • O'Reilly Auto Parts: Carries a full range of Restore products, including 9 oz, 12.5 oz, and 16 oz variants. Customer ratings range from 4.1 to 4.6 stars, indicating consistent demand.
đźš— Performance Feedback
Users report noticeable improvements in engine compression, horsepower, and oil consumption after using the product. These anecdotal results likely contribute to its continued popularity.
While exact sales numbers aren't available, the breadth of listings, customer reviews, and retail presence suggest that Engine Restorer maintains a healthy market footprint.
#28 ·
That's quite a trustworthy source with no product named.
You should give these guys a call. The person you are looking for is Fred Kawasaki, as I recall. Here's his contact info. He's the guy who choose octane ratings.
Kobe Head Office
Kobe Crystal Tower, 1-3, Higashikawasaki-cho 1-chome, Chuo-ku, Kobe, Hyogo 650-8680, Japan
Tel. +81-78-371-9530 / Fax. +81-78-371-9568
#29 ·
Kobe Head Office
RC, just checked my 2019 owners manual. It says use a minimum of 90 octane "TO AVOID SEVERE ENGINE DAMAGE".
#30 · (Edited)
Bob, the recommendations will work perfectly well for you, or anyone else who doesn't care to study the subject as to why. That's what manuals are for. A guick guide that won't get anyone in too deep, or exceed their knowledge base.
#35 · (Edited)
A person can't think of a motorcycle engine as if it's a car engine. Although they have things in common, most motorcycles use a wet clutch.
If you dump this crap into your oil and it causes the clutch to slip, you will be in trouble. Parts will cost 300, or so, and many people would have to have the dealer do the repair, so add another 200 to that.
Mentioning California going down the toilet made me laugh. My dad made the same comment , to my grandfather, in 1972 as we drove through the Haight-ashbury area. The only thing that has changed is the 30,000 dollar house is now worth 3 million.
Reactions: jjscsix
