The slipper has to be added with individual parts, no "kit" available.
The parts are:
13087-0566 Hub-Clutch $207.87
13187-0023 Plate-Clutch Operating $108.47
13089-0024 Plate-Clutch SPG COMP $8.49
16007-0711 Seat-Spring (X3) $1.77 $5.31
92145-1630 Spring (X3) $3.56 $10.68
13272-1413 Plate $7.33
92154-1116 Bolt, 6x35 (X3) $5.13 $15.39
13089-0023 Plate, Clutch,T 2.3 $8.49
Thats the bare minimum, and its what you HAVE to order.
Depending how how close you want to build this to spec, you might need some other things.
They assemble our clutches with a stack height in mind. That simply means how thick all of the clutch plates are when you stack them up. If you want ot built right to the Versys spec of 45.6-46.4mm .
To do this, its advisable to have 3-4 of the kawasaki clutch plates that are 2.0mm thick.
13089-1073 11.00 each
Other thing you might want to add is the versys 100 clutch arm. It is shorter, but barely. Its optional.
Part number 13102-0047
RELEASE-COMP-CLUTCH 44.38
Figure about 400.00 total. When we ordered our parts, online parts were discounted. I dont find that as much now.
It really is plug n play. Theres no machining or special skill involved. Remove old parts, add new parts.
Its a far better clutch than what the bike is supplied with.
A FULL and complete write up is here.
2015 Versys 1000LT Slipper clutch... would it fit ????
