1 - 6 of 6 Posts
For anyone who has changed the countershaft sprocket...is it necessary to remove the lower fairing to do this job?
Discussion Starter · #4 ·
In case you haven't seen it yet, another member was kind enough to do a walk through of the modification: https://youtu.be/SnUV81KugbA
Thanks for that link! Very helpful! That guy just took out a few fairing bolts without actually removing it and that appeared to give him just enough room to work. I think I'll try that approach. Thanks again!
Discussion Starter · #6 ·
Keep in mind when you pull it Ken there could be a lot of crap that comes out. Put a paper underneath. I had a ton of crap/gunk around the countershaft area. Maybe you have less miles than I did.
Good tip. I'll watch out for that.
1 - 6 of 6 Posts
