You have a quart too much. Did you check it with the bike on the side stand?
No it was not on the side stand. Had the bike on a jack stand. I put in 4 quarts, ran it for about 10 minutes. Let it sit for about 20 mins to allow the oil to settle back into the pan. No oil in site glass. Again, it was NOT on the side stand, I know better than that.You have a quart too much. Did you check it with the bike on the side stand?
12mmWhen emptied---replace the oil drain bolt, >>>>
Does anyone know the drain bolt size. I need to get some crush washers. Incidentally, they manual does not require bolt replacement but does ask that the crush washer be replaced.![]()
yes, M12 works.Does anyone know what size crush washer we use? Will the m12 work?
Putting it on both stands is nice, but I still wouldn't base my oil level off the bike while on stands. I've done that before and still put too much oil in it. You want to read the sight glass as it sits how you're going to ride it.Just throwing this out there for future reference.
https://www.amazon.com/Venom-Motorc...674642&sr=8-2&keywords=venom+front+rear+stand
Buy them, lift your bike up and it will be perfectly level for checking oil etc... Best $70 you can spend so you can work on the bike like a normal human being, and not need an extra set of hands. Makes other repairs, lubing chains super easy too.
