Hey all,
I just got done replacing the mechanical seal and oil seal in the water/oil pump. I got it all back together and I can't get oil pressure. Has anyone done this or have experience? The service manual said to fill some space in the oil pump with grease to help prime but that didn't seem to do the trick. Does anyone know how to get the oil pump primed?
I have tried the oil filter trick and taken off the oil fill plug to see if that helps with no success. I have checked the oil pressure with the finger over the hole method and don't seem to have any pressure at 4k (should be about 40psi) I'm scared to run it for very long.
Thanks
Thanks
