1 - 3 of 3 Posts
Hi all, got a 2011 zx1000, got a bit warm and pumped coolant prom header tank, no Temp or light came on. Fitted digital gauge, flushed coolant, added new coolant, new radiator cap and now at 90 deg c ecu shuts engine down and won’t start till cold again.. Any ideas ? Thinking coolant temp sensor
cheers
2021 Ninja 1000 SX
You said you added new coolant. Did you make sure to remove the air from the system? Unless you take an hour filling it, it's easy to trap an air bubble , somewhere in the system.
1 - 3 of 3 Posts
