1 - 5 of 5 Posts
hi all,
on my '15 i started taking apart the rear fender but stopped when the 4 big bolts holding the fender on didn't drop the assembly away. i'm hoping to hear from the guys that have installed a fender eliminator, if i go all the way and split apart the 2 fender pieces, can i access all necessary bolts and install additional spacers to tighten up the loose bits? my ocd won't let this sit alone, and i don't want to jump to a eliminator in case i go with luggage. help.
tia,
parker
I have a '14 with the factory saddlebags, I have a tidy tail on mine that works with the bags. Don't worry about that ugly thing, yank it off, and install a tidy tail.
Unless you live in the PNW, then you NEED that ugly thing to keep water and road grime off of your back...
There are 2 hidden screws under all that junk that hold the fender on. You don't reuse them, but they need to come out before you can get it off. basically need to disassemble the entire sub frame to get to the bastards. you tube is also your friend here, there is a video that explains how to take it all apart. not a hard job at all once you know what to do.
1 - 5 of 5 Posts
