1 - 10 of 10 Posts
2019 Ninja 1000
Sorry for the simple question, but I don't know this bike yet. I've a 2019 N1K and will need to tuck away some wires. After removing the fairings, I may find the need to tuck wires under the tank to reach the battery. Is it OK to just lift the tank up on the hinge? I know some bikes have a stand for this so you don't have to actually take the tank completely off to get underneath. Can I do same here or do I need to follow the procedure in the service manual?
Thanks ahead of time.
Ken
No need to remove the tank, just remove the 2 bolts and lift the front of the tank.
I used an old bath towel rolled up into a "log" to hold the tank in place while I routed some wires under the right-hand side
2019 Ninja 1000
Got it. Thanks mate!
I propped the tank up on a ruler but same difference. Easiest done if the tank is near empty. I ran my wiring up the clutch side.
Tank
I did it by loosening the bolt at the rear of the tank where there is a hinge, then removed the two bolts at the front. The tank was lifted/rotated up and propped with a small board wedged on the tank and triple tree being careful about the rubber hoses that run along the bottom of the tank.
I keep mine pulled back with a bungee cord to the rear seat latch. Have to use a polishing rag up on the tank to keep the bungee hook off of it.
2019 Ninja 1000
Discussion Starter #8
GSXR's come with a tank stand. I have a couple of them and use them often.
Thank you!
Thank you!
Thank you!
I've had good luck using a half used roll of paper towels. Stuff it back near the pivot point. Much safer than when I end up bumping the rod, and knocking it across the garage. I've done that 20 or 30 times, no idea why
Basically anything you can find in your garage to use as a wedge is fine. I typically use a piece of 2x4.
1 - 10 of 10 Posts
