1 - 2 of 2 Posts
It took 5 years but I finally slammed the garage door down on my rear license plate light assembly. I tried to fix it but failed. the part i needed was not available unless i bought the whole assembly for 60 bucks....dam
Discussion Starter #2
I began trying to remove the oem system. Never down this before. Jeez...I practically had to remove the rear tail to figure it out. Having little experience, I finally got the part with the bulb removed and traced the wire back to the harness. I removed the old wire and accompanied parts and have now replaced the end with the new housing which screws into the existing tail area. I still have to re-route the new wire to the harness and close up the bike tail. Hope I can replace all the screws in their correct locations. All I can say is...dam.
1 - 2 of 2 Posts
