1 - 12 of 12 Posts
· Registered
I've got Kawasaki Ninja 1000 specs for everyone to ogle at.
Engine
Four-stroke, liquid-cooled, DOHC, four valves per cylinder, inline-four
Displacement
1,043cc
Bore x Stroke
77.0 x 56.0 mm
Compression Ratio
11.8:1
Fuel System
DFI® with four 38mm Keihin throttle bodies, oval sub-throttles
Ignition
TCBI with digital advance
Transmission
Six-speed
Final Drive
X-ring Chain
Rake/Trail
24.5 deg / 4.0 in.
Frame Type
Aluminum Backbone
Front Tire Size
120/70 ZR17
Rear Tire Size
190/50 ZR17
Wheelbase
56.9 in.
Front Suspension / wheel travel
41 mm inverted cartridge fork with stepless compression and rebound damping, adjustable spring preload / 4.7 in.
Rear Suspension / wheel travel
Horizontal monoshock with stepless rebound damping, adjustable spring preload / 5.4 in.
Front brakes
Dual 300mm petal-type rotors with radial-mount four-piston calipers, optional ABS
Rear brakes
Single 250mm petal-type rotor with single-piston caliper, optional ABS
Fuel Capacity
5.0 gal.
Seat Height
32.3 in.
Curb Weight
509.4 lbs.
Overall length
82.9 in.
Overall width
31.1 in.
Overall height
48.4 in.
Color(s)
Pearl Stardust White/Metallic Spark Black, Candy Lime Green/Metallic Spark Black
Warranty
12 Months
Good Times™ Protection Plan
12, 24, 36, 48 months
· Registered
The black color looks the best to me so far. There is something about an all black motorcycle that reads "badass." It is really unclear what color options are going to be available in which regions though. The website only shows blue and green as color options.
· Registered
and add a carbon fiber exhaust or some shorter GP style exhaust and it will be clean! the stock exhaust system isn't helping.
1 - 12 of 12 Posts
