I may be trading in my concours 1400 on a ninja 1K but one thing i want is to be able to mount the v47 top case to the ninja, has any one done this & if so can you please point me in the right direction! thank you
As far as I can tell, the Givi 2011-2013 saddlebag + top case mounts work on the 2014-2015 model, but the Givi top case mount will NOT work with the OEM panniers.Is the 4100FZ + M5 plate works with the Kawasaki factory side case on a 2014-2015 Ninja 1000 (not the Givi side case/bracket)?
no they will not work with the factory mounting brackets, this info is directly from givi as well.Is the 4100FZ + M5 plate works with the Kawasaki factory side case on a 2014-2015 Ninja 1000 (not the Givi side case/bracket)?
