If the Z1100 comes in the '25 Z900SE color scheme, it'll be a hard bike to say no to.
949 views 23 replies 3 participants last post by  rcannon409
The z1000 was available everywhere else until 2021. It really didn't have a change from the 2014 version. The new version should look something like this, with maybe, possibly a different shade of black.
for the USA. It has to fit within the z900 series and the zh2 series, so there's not a good option for much else.
The z 1000 was never popular here. When I bought my new 2012 ninja, I could saved thousands on a 2010 z1000. It stayed in the shop for a long time. I've only seen one out on the road since 2010.
I think now is an odd time to get into this category. Honda just released their Hornet with an ohlins shock, Brembo calipers and 11,999 cost. With a good flash and exhaust, it will be a 160 bike before you start borrowing parts from the 2008 cbr 1000. The z1000 doesn't photograph well, but in person it's a nice bike, but it won't be able to compete with the Honda.
We don't even dare hope for that, do we?
The z900 frame with boxy zrx bodywork would be different and cool. Load it with the good electronics to make it an upgrade from the z900 that's already a 948cc bike.
No, I think I already saw the Kawasaki van drive to Home Depot for the black paint and a set of paint rollers.
Matty, now that you mention it, the last z1000 I saw for sale was in 2014. I've seen that orange 2010 I mentioned and a green 2014. That's it.
A z900 based bike would be easy to build. The z900 engine, z 1000, and this 1100 all use the same engine block. We could build this z1100 or a z900 ninja in our garages if we wanted to.
This is a Japanese kit for the z900 series. I say "kit" but it's probably 1 of 1.
Reactions: MetalMatty
I would as well, or this one. This one is supposed to be a "kit" from Japan, but I've never seen it for sale. As I recall the tank piece was a little bit sketchy, but that wouldn't be an issue if Kawasaki built it. This would be very similar to the z900 rs only the retro look is 82 vs the mid 70's.
Our local dealer did have an 82 elr. He had it on the showroom floor and its price was "Taking bids, cash only". It never had a retail price although 4400.00 was mentioned. The not green kz1000 was about 3000, so it was expensive to try and own a real Lawson replica street bike. The 83 had slightly different paint and was nearly as limited in production numbers.
The left rear shock has some issues, but those could be left off without hurting the look. There is a web site called "Planet Japan" that features these project bikes. The info is translated from Japanese to English so you never know how legit the descriptions are.
You also mentioned how small they are. That's what I noticed about the kid I saw riding the z1000. I noticed how large the rear tire was and how minimal the bike looked. The rider appeared to be normal size. It was a good demo to see how small the frame is on our ninja 1000 as compared to a First Gen fz1 or Suzuki bandit. Both of those bikes were size large....we have a medium.
I looked at the Versys, and it is larger, but not that much. It was a confusing bike. They are all based around that original z1000 frame and that makes for a small bike. I think that keeps costs as low as they can be, but doesn't make for comfortable touring bikes.
If I were any larger I would find a Suzuki bandit 1200 and build a project bike. They don't sell for very much, used, and with a fork and shock swap you would have modern brakes and good suspension.
It's an old GSX-R based motor, so you can have about any horsepower level you want. A first Gen fz1 would be a good choice, too. The zx14 would be decent, but the low bars hurt its comfort level.
I would want to ride one before I bought one. The seat was nice, and the taller bars were comfortable , but the wind protection wasn't that great and the motor wasn't near what we have in the old Ninja. It didn't feel bulky compared to a Concourse 14, but the fun feel we have wasnt there.
If you have Ivan flash it, you'll know what the low end is supposed to be. I think Kawasaki was worried because the bike didn't have traction control so they limited the low end power and that hurt throttle response. Then again, they still limit low end power, so who knows why?
You'll know a lot more once you get your ECU back. Our bike is two different topics. With flash vs without flash. It's a dramatic difference on these old bikes.
If you talk about our modded bikes vs a stock versus, it's a 40 HP loss. It's fixed for 2025, but it never made much sense.
Maybe it fit in the line up better with lower power? It should be a move up if you bought a Concourse 14 or zx14, and maybe even the H2 sx? It also made it a performance jump if you bought the more sport oriented ninja 1000? Ok, I tried. I would have had a hard time selling that crap in a meeting. The ninja and Versys are not similar enough to compete with each other, are they? Using the same motor would have saved hundreds of thousands in emissions testing as well.
A tune worked very similar to what it did on our bikes, but it started at a lower number. Versys stock was around 100-105 HP. Modified, with a good exhaust 115-120.
Ours started 20 HP higher. 120 stock, 140 modified. The cams are different and I think it runs lower compression, so it was quite a bit different. It did have a better, wide ratio transmission.
This is common sense, but it has always fascinated me. With any engine, you have to give something to get something else. If you build strong low end, you can't have high top end. Strong low end doesn't mix well with strong top end. Supercharging and turbo charging blur the lines on this, somewhat. Larger displacement does as well. BMW and Suzuki both use a vvt system that helps, but still doesn't change the give to get idea.
The first Versys would have been introduced in late 2011 as a 2012 model. We didn't see it in the USA until a few years later as it was a European bike. I think the first Versys for USA was in 2014, or 2015.
The one thing that stands out is that it makes more power than Suzukis v strom 1000 and that bike was popular. I've never seen anyone complain about its performance. The big complaint was about how it looks. Now it's looks and cost. The only version we get, in the USA, is the top of the line machine with electronic suspension. It does come with bags, but its 19,500 before the other fees. Even with a 3000 discount it would feel too expensive.
