Gear shift fail and result in false neutral
3.8K views 6 replies 4 participants last post by  Biker087
#1 · (Edited)
Hi sometimes when I change gears on my Kawasaki ninja 1000 2013 the gear do not engage and the transmission kind of fall between 2 gear (false neutral) and I hear noises.
This happened when I bought the used bike 3 years ago, and it happened a couple times since then. I went to a garage and they said the clutch cable was stretched so they had it adjusted. Since then it is much better. Anyone experienced it?
#2 ·
I have a 19 and have had something similar happen and took me by surprise. Hasn't happened often but the last time stood out as loud. I thought it had to do with my technique being off, but I truly wasn't paying attention to how that came about.
I'm going to see if thjs happens again and more frequently and whether I was properly using the clutch or not.
#3 ·
I've had this happen once or twice. Sort of. Go to shift between any of the other gear combinations besides first to second, and the thing falls into a false neutral. Could be the shift detent spring being weak. That's a bit of a problem on our bikes, I'm to understand. I just installed the Factory Pro shift spring on mine this morning. Haven't ridden it yet but just shifting it on a paddock stand feels really good and positive. Not weak and whimpy like before.
