1 - 9 of 9 Posts
I've used these for maybe around 2500 miles, and then I bought a pair of 320mm Brembo T-Drive full-floating discs with a floating rear, mostly because I'm an idiot who likes to set money on fire. Regardless, my previous Brembo 310mm discs are up for sale.
They are a direct bolt on for all years of Ninja 1000's, though they do require a 5mm caliper spacer to be used (since stock disc is only 300mm), they are around $20 on ebay, though you can still reuse your stock caliper bolts as they are plenty long enough, or at least mine were.
I've spent the last group ride feeling every one of my buddy's disc to see how the wear compared to mine, and I can say with confidence that these do not have any noticeable grooves that can be felt with a finger. Also they are completely straight.
I'm asking $280 for the front pair, and an additional $50 for the matching rear disc. Buyer pays actual shipping.
Here are some temporary images until I get them off the bike and take some more close ups, after I install the T-Drives later this week.
31371
31372
I have this exact disc on both of my bikes. They are from the zx14 se that has the brembo brakes. They are .5mm more thick than normal discs. Very strong, and still pretty light.
They are made to stop a 600lb zx14 from 190mph. Used here, on a ninja 1000, I would suspect you might be looking at a lifetime sort of disc. If you wear one of these out, I'll send you a trophy.
Hes pretty well giving them away at this price. I would buy them, but even as goofy as I am, havi g a set of these for back up isnt necessary or they would already be in the mail.
Thanks RC. My Brembo M4's are also going up for sale shortly, I ordered new GP4-RS calipers, but they are on backorder until late June, early July, so once I get those in I'll toss the M4 on here as well. Probably for the same $280 as the discs.
Attached are the images of the discs off the bike. I've tried my best to convey that there are no grooves in the disc but it's pretty much impossible to show that on camera. You have to feel it with your fingers to convince yourself. As said previous, the radial lines you see on the friction surface is pad material, even a new bike with 100 miles on the clock is going to have that, it's completely normal.
85745
85746
85744
Discussion Starter · #9 ·
The front discs are now SOLD to someone with a 4th gen ZX10r, though that bike would have seen the least benefit from these, as that bike already came with 310mm discs as stock. I guess he hated the petal look as much as I do. :D
Still have the rear disc for sale, $50 for anyone that wants them, though they are nothing special, just non-petal round disc, same as stock..
1 - 9 of 9 Posts
