I just received some Shogun frame sliders. I'll need to remove a couple of bolts going through the frame and into the engine. Does anyone know what to torque the bolts to? Thanks.
I recently installed a set of T-Rex sliders on my '15. Their instructions say that the M10 engine bolts should be 35 ft\lb and the M6 bolt (that holds the cable bracket) should be 10 ft/lb. However, the shogun sliders may not require removal of the M6 bolt.
Thanks. The Shogun sliders only state to check the manufacturers torque specs, which leads me to believe they are a bit generically engineered. Also, the bolts they supplied don't not go into the engine quite as far as the original bolt.
