1 - 1 of 1 Posts
Have you guys got any? I have so much downtime between work and weather. Sometimes I'll get carried away.
If I remember correctly, the 2014 ninja was the first Ninja 1000 to have the guard on the front of the swingarm. I made one out of a trashcan, and bolted it in place. I'll ad a picture. It helps keep road trash from the back of the engine.
It's also a good time to make sure the connection between the voltage regulator and the bikes harness is clean and dry. It's in a terrible spot on the earlier bikes. Water gets inside the plug. If you open it up, occasionally, you can add the electronic grease and seal the plug with zip ties. If you havent checked this, do it today. If water gets in there it will damage the regulator, stator, and wiring harness.
1 - 1 of 1 Posts
