Can you please send the pic of the water pump hose and locate it on the Bike.If you follow the Service Manual, and use the coolant drain plug, located on the water pump, then you will not get all the coolant out as the hose from the bottom of the radiator to the water pump is below the level of drain plug hole.
If you want to drain all the coolant, then forget about the drain plug and just loosen and remove the coolant hose from the bottom of the water pump.
Oh ok. Will check it out. ThanksYou wont need a pic. Look at the bottom of your bike, left side, under the engine. There is your hose.
Thank youIf you follow the Service Manual, and use the coolant drain plug, located on the water pump, then you will not get all the coolant out as the hose from the bottom of the radiator to the water pump is below the level of drain plug hole.
All this process should be done only when thOh ok. Will check it out. Thanks
Oh, ok. Thank you for detailed explanation. Will check that video too.As RC has commented, you really dont need a photo.
- Take the left-hand (gear shift side) fairing off the bike and find your radiator. Jason Long on YouTube has a video on how to do this.
- At the bottom, left-hand side of the radiator is a rubber hose. Follow that hose back under the engine to where is is clamped to a steel pipe.
- Undo the hose clamp on the radiator and the hose clamp on the steel pipe
- Wiggle/push the rubber hose off the steel pipe and drain the coolant.
Ooooooops ... my mistake, it is Johnathan Long and the link to his excellent video on removing the N1K fairings isAs RC has commented, you really dont need a photo.
Jason Longon YouTube has a video on how to do this.- << SNIP >>
No problem. I checked jonathan long’s coolant change video. But, he also uses Drain bolt, Not the water pump pipe.Ooooooops ... my mistake, it is Johnathan Long and the link to his excellent video on removing the N1K fairings is
Anyways, I’ll do the both ways. I’ll drain from the drain bolt and also disconnect the water pump pipe. There’s another channel called ‘i am scud’. He has done it both waysNo problem. I checked jonathan long’s coolant change video. But, he also uses Drain bolt, Not the water pump pipe.
Of itself, there are no adverse effects, provided the cooling fan moves enough air through the radiator to meet or exceed the amount of heat being put into the coolant by the engine.Other than the fan coming on, what are the ill effects on the Ninja? I've done my share of sitting in traffic in 100+ degree F heat and other than the fan cycling on all the time the bike hasn't "overheated." I, OTOH, seriously overheated.
