depends what you're looking for. You can fiddle it for more top end, or more low end.. all depends on what you need/what you want...What exactly would be the difference? Better top end or acceleration..lower rpm's!
great link, cheersYes, its an ok mod..the one tooth larger. Your looking at a small rpm drop, though. This site is fun to experiment with:
Gearing Commander: Motorcycle Speed, RPM, Chain & Sprockets Calculator
On this bike, you cant sprocket change enough to forget how close the ratio in 3rd, 4th and 5th are...they are more like 3a, 3b and 3c in feel.
Still, gearing commander gives you a good feel for the rpm change. And one tooth is barely noticeable.
I'd also like to lower RPM in 6th. What if we went 1 up and 1 down ?Yes, its an ok mod..the one tooth larger. Your looking at a small rpm drop, though. This site is fun to experiment with:
