Question. I took my front and rear wheels off to get new tires. Everything came off and went back together as it should. Now the ABS light will not go off. I notice that there is a timing plate on each wheel for the ABS sensor that I am assuming is used to sense pulses front and rear to see if one wheel is sliding faster than the other. As far as I can tell, everything is where it should be. Is there an alignment process to get the ABS sensors aligned with the notched plate on the wheels? The ABS light always comes on when the bike is first started. But when the wheels go around a few full turns, it usually turns off.
If the sensor do need to be aligned, how do you do it? Wheels are on correct and felt fine on the test ride.
Any ideas what may have happened? I do disconnect the brake and ABS lines when I use the front fork stand. And have done that many times with no issues.
Any ideas would be appreciated.
