Went to finish up my rack and the bracket that goes under the pavillion where the tail tidy is bolted want work, evidentally its made to work with stock mount and not after market tail tidy. But from the size of the four bolts holding the arms to the side frame ought to be plenty to support 10 or 15 lbs especially since the arms are box construction, i think the tail bracket is to keep it from rotating down, after tightening it up and putting alot of down pressure on top box the rear spring was compressing, the side arms did not have much deflection, i might fabricate another support after trying it out first. Any body else run into this
