21 - 30 of 30 Posts
Discussion Starter #22
Which full exhaust did you put on and are you experiencing any engine performance issues due to no ecu tune ? I have the Akro slip on my 2020 N1k and just got the Akro headers. Want to install them but don't want to cause any problems running the engine without an ECU tune. So also waiting for confirmation of tuners for the 2020 model. .
I have full akro system with no issues. It pops on upshift with hard acceleration but it idols fine. Gain about 10 hp also
Hey - thx for reply. So just to confirm, your running full Akra headers and slip in with stock ecu, no ecu tune. Is that correct ? Thx again.
You dont need to remove/move the radiator. The access isnt great, but once you remove the nuts, on the header to cylinder head portion, it will slide right off.
I used a 1/4" drive set with a wobbly. The top nuts are not easy to get to, but it beats removing the radiator.
You'll be surprised at how much room you really have once the plastic is off.
21 - 30 of 30 Posts
