2014 Kawasaki Ninja 1000 Key Features
1729 Views 7 Replies 5 Participants Last post by  KawiRider
• UPGRADED 1,043cc inline-four with DFI® offers even more power and torque for effortless passing and backroads entertainment
• NEW KTRC Traction Control system features three different modes for maximum performance and enhanced rider confidence in varying conditions
• NEW Selectable Power Modes offer a choice between full power and approximately 50 percent power output to help suit changing conditions
• NEW One-piece “monobloc” radial-mount front brake calipers offer superb braking power and control, along with a premium laser-etched Kawasaki logo and black alumite finish
• NEW Taller 6th gear provides a more relaxed ride when covering highway miles
• NEW Analog + Digital instrument cluster includes a large tachometer and a digital display with a wealth of information current bike conditions and settings
• NEW Remote rear spring preload adjuster allows quick tuning for passenger and luggage weight
• NEW Subframe with built-in compatibility for Kawasaki’s new accessory saddlebag mounts
• NEW Optional dealer-installed saddlebags are cleanly integrated with the new subframe and can be removed in seconds and leave a clean, rack-free tail section
• Relaxed, upright riding position contributes to all-day comfort and impressive maneuverability
• Lightweight aluminum frame is narrow and tuned to transmit optimal feedback to the rider
• Fully adjustable inverted fork has settings designed for sporty performance and ride quality
• Design of horizontal back-link rear suspension contributes to mass centralization
• Radial-mounted front brake calipers combine with the radial-pump front brake master cylinder and ABS to offer superb control and feel
• Sleek, supersport styling gives the Ninja® 1000 a distinctive look
• Larger fuel capacity offers substantial range
• Windscreen is adjustable to three positions, allowing for optimum wind and weather protection
1 - 8 of 8 Posts
The changing power modes is interesting. I usually think of different driving modes affecting things like suspension not the power of the bike. Changing to half power is quite the change though. I wonder how many people would want to turn on a mode that lets you go half as fast? maybe if you are just going around the city.
What exactly has changed compared to the 2013 Ninja 1000?
I think that all of the things that say "new" are likely different from the 2013 model. And the "upgraded" one is probably improved from the last model. :)
you'd likely want to use low power when cruising the freeway. Its like those V8s from GM that shut down 4 cylinders under high sspeed cruising
Yup, when it comes to cruising, that the best thing to do, ideal when you're just commuting to work and back, no need to ride like a hoon
I wonder how the 50% power mode effects mileage
chances are it boost gas mileage up quite a bit, there doesn't seem to be any reports or solid info on it, we'll have to wait.
1 - 8 of 8 Posts
