From 2014 onward you get traction control, ABS standard, 2 power modes and a new rear subframe that now allows for much nicer integrated factory hard luggage. A minor motor change was made to make the strong low-end power even better. Improved brakes with monoblock calipers up front. A minor, virtually unmeasurable change, was to make 6th gear a bit taller, still should consider going with a 16T countershaft if you spend much time on the highway. Those are the high points besides color changes.
I would pass totally on the 2013 and not even consider it unless it was super cheap. The changes are significant starting in 2014.
