1 - 6 of 6 Posts
2013 ninja 1000SX
I’ve been looking into getting an aftermarket fuel pump for my 2013 N1K SX so does anyone have any suggestions? I’ve been trying to find the LPH and PSI for the oem fuel pump so I can make sure the aftermarket pump actually has higher specs than the OEM but can’t seem to find the specs for the OEM pump , would anyone know them by chance?
2014-2016 Shop manual says 43 psi with engine idling; 50ml or more for 3 seconds.
Haynes says same but for both 2011-13 and 2014-16.
Same specs for the 2017 ~ 2019 models.
Fuel Pressure (High pressure Line) = 294 kPa (3.0 kgf/cm2, 43 psi) with engine idling
Discharge = 50 ml (1.7 US oz.) or more for 3 seconds.
What is is you are trying to do? Are you modifying your bike? If not, this really isnt an area you want to upgrade.
2013 ninja 1000SX
I already have the a full system and fuel command module on it. I’d like bigger injectors and an aftermarket fuel pump and after all that get a tune for it all.
1 - 6 of 6 Posts
